I am shooting oil out of the dipstick hole, what should I do?
Old Aug 6, 2001 | 05:20 PM
JucinGTA's Avatar
I silicone it a little, where it goes into the block, but at about 3rd gear, at 4 grand it finally spits onto the header, and makes my car look like it blew up, cause it smokes so bad What should I do, Im gonna stick a new one in there tomorrow?
Old Aug 6, 2001 | 05:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You probably don't want to hear this.... but if oil is being shot up out of there, you have much bigger problems than just looks. You have ALOT of combustion blowby getting into your crankcase. You probably have a piston (maybe more than one) with the spark plug side melted off.
Run a compression test, or preferably a leakdown test. That will at least tell you which cylinder(s) are the culprit.
If you get the tube to seal where it goes into the block, it'll just blow out of somewhere else.
ICON Motorsports
Old Aug 6, 2001 | 07:59 PM
Vader's Avatar
...A little whiff of the blue bottle goes a long way toward melted piston tops...
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 6, 2001 | 08:17 PM
JucinGTA's Avatar
Alls I will say is forged pistons on a egine with about 3,000 miles!!!!!
Old Aug 6, 2001 | 09:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I blew my dipstick right out. Of course there was a hole in the top of the piston the size of a valve stem when it happened
Oil out the dipstick means too much crankcase pressure. Do a compression test. Also check the PCV valve.
The tube should also be a very tight fit. You shouldn't be able to just pull it out of the block. Try a new dipstick tube.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Hotrodboba400
Dec 10, 2019 07:07 PM
carattini
Sep 10, 2015 07:46 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
