88 GTA L98, complete tune up tips pleez!
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Hey all, want to give my new 88-GTA-5.7 a good tune up. What's the best way to go as far as new plugs, wires, cap what else should i do??? I want to mod it up slowly step-by-step.
thanks!
thanks!
I would go with a cap and rotor from MSD, bosch plugs(platinum or +4), and some 8mm wires that cost at least $40(hey if they're more expensive they should be better right?)
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
'86 IROC 5-speed
305 LG4
msd pro billet hei
'95 3.23 rearend
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Change your PCV valve also, and maybe your fuel filter.
Later
Mike
(Gran Turismo Americano) "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Later
Mike
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Get an MSD Cap an Rotor. For me I stay with good old AC Delco Plugs. For Wires I would go with MSD or Taylor 8mm Wires. Accel wires have been known not to be any good. A new fuel filter would be good and maybe take out the PVC and clean it with a can of carb cleaner. Timing your car would be good too. Time it to 6* Stock to start. Adjusting your IAC and TPS is also good. If your idle is where you want it just check the TPS to make sure its within .54-.56 volts. Next check the air filter, and change all fluids including the Diff. You probebly have a posi rear so remember to add the posi lube from GM. Swap motor oil over to Mobil 1 and your all set.
89 FORMULA 350
99 Grand Prix GT
89 FORMULA 350
99 Grand Prix GT
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Look at the Tech Articles section for "Suggested Mods for TPI Engines".
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
