sensor/green wire??????
Old Apr 22, 2005 | 10:12 AM
dark scorpion's Avatar
Car: 1990 gta
Engine: 5.7 l 350 v8
Transmission: automatic
Hey all,
Yesterday I jacked up my 92 bird to check to see if all the plugs are ok. They are. Then I get to the passenger side and I see a
thin green wire with a suction cup type grommet on the end. I
have NO IDEA where it goes. I look around and between the
number 8 and 6 plug openings I see what looks like a sensor.
I would like to know if ANYONE knows if it is a sensor and what
sensor it is. Also, if they know if that thin green wire goes to it.
If not, does anyone know where that green wire might go? It
is in the same wire loom as the starter wires.
This wire is more than likely the reason my car cranks and does
not start. Some how some way that wird came loose from something.
Any help, suggestions are greatly appreciated.
I may get this thing running after all.
Old Apr 22, 2005 | 10:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is the fan switch.
Yes a dark green wire with a single round Weatherpak goes to it.
No it will not keep the car from starting; it will simply keep th eelectric fan from working at some of the times that it's supposed to.
Old Apr 27, 2005 | 11:46 AM
Car: 1990 gta
Thanks.
That's a relief. It just kind of pops right back on right?
This would explain why I haven't really heard the cooling fan
run (when the car actually did start).
Old Apr 28, 2005 | 10:24 AM
Damon's Avatar
Yeah, it should just pop back on, but the connector and/or the sensor itself is often damaged (they're just plastic). Somehow get it hooked up again.
If your car is just a single fan system that is the ONLY sensor that will turn on the fan (unless you turn on the A/C) and it does so around 228*F coolant temp.
Old Apr 28, 2005 | 12:58 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
88'IROC-Z 5.7L TPI
The fan switch of a single, or dual fan system will only turn the fan on at 238°.
The A/C has a pressure switch that will also turn on the fan at 233 psi.
The ECM will turn on/off the primary Fan, or single Fan at whatever temperature it's programmed for using the Coolant Temperature Sensor on the front of the Intake.
Old Apr 28, 2005 | 02:07 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
It should be clarified for the poster that for a '92 Firebird with the L03 5.0L TBI engine, the cooling fan (there is only a single fan on TBI cars) will only come on via that switch.. The '8746 ECM has no provision for cooling fan control..
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
