Accell fues pressure gauge question
Old Aug 7, 2001 | 08:15 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Does this gauge mount permanently under the hood, or is it just a test only and take off piece?
If it does not mount permanently then can you direct me to a gauge that does mount permanently under the hood?
***The driver formerly known as 89IROCZ***
1989 Chevrolet Camaro IROC-Z
350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back (currently no muffler, sounds on webpage), SLP 1 5/8 Coated Headers on order, 3.23 Posi rear, Hypertech chip with 160stat, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, throttle body coolant bypass, Spohn SFC's on order, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info, pictures and sounds (of the IROC) available on my webpage: http://go.to/iroc-z
AOL IMer: GPA 0point0
Old Aug 7, 2001 | 11:12 PM
Andy89RS's Avatar
Unless it uses a short rubber hose with a fitting on one end to attach to the fuel system, and the other end goes straight into the gueage, it's probably a permanently mounted guage. The following link will get you to Summit Racing's guage and guage accessory page, just click on "Fuel pressure guages" to see all that they offer. Also, if you get an isolator you can mount the guage inside the car. http://store.summitracing.com/defaul...tment.asp?d=10
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
