cooling fan only works with AC on
Old Aug 7, 2001 | 04:26 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Posting this for I guy I just met. He has a '92 RS 305. The cooling fans will only operate when the air conditioning is on. With AC off, no fan, car overheats. Thanks.
87 Formula 305TPI T5
Old Aug 7, 2001 | 04:36 PM
Stuart Moss's Avatar
If you have one fan: a bad Coolant Temperature Sensor (CTS) located by the thermostat with two wires may not be giving the ECM the proper temperature (resistance).
If you have two fan's, a bad coolant fan switch located between cylinders 6 & 8.
On a 92 V6 I had (one fan controlled by the ECM), I had a bad CTS. I could get the fan to operate when I removed the two-wire connector to the CTS with the engine running. Perhaps this "test" will work with the 305 too...
The CTS is the first thing I'd look at.
Old Aug 7, 2001 | 11:47 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I agree with Stuart on this one. It is the CTS the exact same thing happened to me about a month ago and when I put the new CTS in it was all good no problems.
Old Aug 8, 2001 | 11:03 AM
Kiss_My_SS's Avatar
I was having the same issue and replaced the CTS. The fan comes on but not until about 230. Is this normal? Also the heat never really gets real hot.
Thanks.
Kiss_My_SS
1992 Camaro RS/Heritage Package
1996 Impala SS
1985 Good ol' Chevy 4x4 Truck
eightsixseven
Dec 16, 2024 01:50 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
