Ign Key Turns Freely
Old Apr 25, 2005 | 08:43 AM
NEOMASTERZ28's Avatar
Car: 85 z28
this happen last nite , i went to start the car heard someting click and snap then , the started to move freely in all postions
so to get home i just pulled the rod to start it to get home ,
any ideas on what i should replace , friend of mine said it happen to him he jus went to the junk yard and bought a sterring coumlum ?
can any shine some light on this thanks
Old Apr 25, 2005 | 10:46 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
What has happened, more than likely, it the rack, or pinion gear, or both, in the left side of the column, have broken. You can replace these parts, but tearing down the steering column is required. Need a steering wheel puller, and a lock ring compressor. You can rent these tools from many locations if you do not have them. Not a difficult job, just time consuming. Replacing the entire steering column would be over kill.
Old Apr 25, 2005 | 10:48 AM
Car: 85 z28
so whould, buying a new ign lock solve this ?
Fronzizzle
Mar 18, 2019 08:29 PM
GTAman
Sep 21, 2015 09:57 AM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
BrianI
Aug 9, 2015 11:52 AM
