Old Aug 8, 2001 | 07:40 PM
82Trans Man's Avatar
400
I am hoping that someone can help me with this question. I am able to get two 400 Pontiac wide blocks free the only catch is niether have a flywheel. Somone said the 400 pontiac is a externally balanced engine and I'd need the original flywheel from the engine, but I know there is a guy in town that balances complete rotating assemblies. My question is does anyone know if I can get a different flywheel balanced? Thanks in advance to all that can help. James
Old Aug 8, 2001 | 09:56 PM
iroc5speed's Avatar
I don't see why you couldn't, you can get everything else balanced.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Old Aug 8, 2001 | 10:08 PM
93ND500's Avatar
You would only need the original if you did a basic rebuild with no machine work...ie rings, bearings, gaskets..... If you had core parts replaced (crank, rods, pistons) you would need to have it re-balanced anyway. Then you could give another flywheel and have him balance it to the rotating new assembly.
Old Aug 9, 2001 | 07:11 AM
Alright that confirms it. I thought it would work but the problem that I was tring to avoid was making myself look ignorant and have him try to take advantage of me as was my last dealing with a machine shop (T.S. Machine in Busti NY). Thanks Alot James
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
