New calipers on 88 and earlier rear???
Old Aug 9, 2001 | 08:47 PM
matty350TPI's Avatar
I have a 9 bolt rear end with I think the early style calipers. Now can I change to the later style calipers? Do I need new rotors or can I stay with the relatively new ones that are on there now. Any ideas guys?
1988 IROC-Z T-Top "MATTSTOY"
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch, Spohn Sub-frames, Jamex 1.5 Lowering springs, 2 1/2' Exhaust,ram air setup
Old Aug 9, 2001 | 09:46 PM
Guest
Guest
Posts: n/a
You need a bunch of stuff, like calipers, hoses, caliper mounting brackets, slide pins, rotors... lots of cost there, but it can be done. I think the e-brake cables are different too.
Old Aug 9, 2001 | 11:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's all different, nothing interchanges. But you can change over the entire system as a complete unit including the backing plates, calipers & brackets, lines, and parking brake cables; as an assembly it all bolts right up. You just have to find a donor rear end and take your axles out to do it.
ICON Motorsports
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
