oil dipstick..
Old Aug 10, 2001 | 08:39 PM
rezinn's Avatar
oil dipstick..
Where does it go into the block? above the starter? beside? I can't seem to find the hole.
Old Aug 10, 2001 | 08:57 PM
Scott 87 IROC-Z's Avatar
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
It right above the oil pan by the starter.
87 IROC-Z 305 TPI gears, exhaust, converter
14.70 at 94.1 mph
Solid Roller Minirammed 377 - It's Alive !!!
Old Aug 10, 2001 | 09:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends on what year the block is. Dipsticks up to 1979 are on the left hand side (drivers). All SBC blocks from 1980 to present are on the right side (by the starter). There's a small hole in the block. The tube is pressed into the hole. Hammer and a screwdriver usually work well for installing the tube.
Old Aug 10, 2001 | 09:58 PM
rezinn's Avatar
I took the starter out and I can see the hole, I cant twist the dipstick in though.. I've got it in a vice right now because it wasn't straight enough, thanks.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
