Keith Black
Old Apr 29, 2005 | 03:23 PM
chevyz71man's Avatar
Keith Black
Anybody deal with these pistons? I got a set for my 383 and the pistons say that for every 1" of bore you need .008" end gap which would make .032". The chevy rebuild spec book calls for .010"-.015". and the rings say I need .004" endgap for every 1 inch of bore making .016" end gap. Just wondering if anyone has used these pistons and what did you set the endgap for? My rings right now show .013" of endgap.
Old Apr 29, 2005 | 04:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
I haven't used those pistons specifically, but the word is follow the piston manufacturer's recommendations.
Also, this is more of a Tech/General Engine topic than Engine Swap, so moving there.
Old Apr 29, 2005 | 05:40 PM
ede's Avatar
ede
i've used alot of them in SBCs, follow the makers spec. the spec in your manual if for the factory pistons, not KB replacements. i use a ring filer, lot quicker and simpler to do that way.
Old Apr 29, 2005 | 06:53 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I used those pistons with decent success. The ring gap reccommendations must be followed. Be prepared to use plenty of oil when cold. Every motor I used with kb's made piston noise and used oil. However they ran well.
gta892000
Aug 11, 2019 11:16 AM
Saxondale
Sep 15, 2015 06:42 PM
m00n420
Sep 11, 2015 02:39 PM
Ironhead38
Sep 7, 2015 02:26 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
