Lower T-stat w/ mechanical fan
Old Aug 11, 2001 | 07:02 AM
MartyMcFly's Avatar
Car: Z28
Engine: Edelbrockified 305
Transmission: 700-R4
My 85 Z used to have a 160 thermostat, and I would notice that if I let it idle in hot weather, the thing would heat up to over 220 or so but then stay there. Someday I'll proably put it back in, but I need to know this first: Is there a way to make the fan come on at say, 170 to hold the temp there? Or does the fan always stay on? I know the guys with electric fans can use a different fan switch to make their fans come on at different temps, is there anything like that I could do?
Ludicrous Speed GO!!!
Everyone come to the Vicksburg Old Car Show (in Michigan) next year, and hold it up for all the Thirdgen owners out there.
e-mail me for directions, dates, etc.
[This message has been edited by MartyMcFly (edited August 11, 2001).]
Old Aug 11, 2001 | 07:26 AM
Bjase's Avatar
Car: 88 IROC
A thermostatic clutch fan does that from the factory. And the coolant thermostat. You could switch to an electric fan, they're not that expensive.
Old Aug 11, 2001 | 09:31 AM
Vader's Avatar
...or you could get a thermostatic clutch fan hub from a truck. They tend to operate at lower temperatures and would pull more air belox 220°F. I had an '88 Astro van that would cycle the fan at about 150° air temperature (probably 170° coolant temperature). The hub is the same size, and the entire fan might even fit your shroud without changing the blades. I'm thinking twenty bucks at a bone yard would be a lot.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
tommy z-28
Oct 6, 2015 10:58 PM
Kylej68
Exterior Parts Wanted
Sep 28, 2015 10:00 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
