MSD Distributor O-Rings
Old May 1, 2005 | 09:39 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Folks,
There are two O-rings on the MSD distributor, an upper and a lower one. The upper one seems fine, but the lower one seems to get cut or broken when inserting the distributor. This has happened three times, even though I've been careful about putting it in and taking it out.
So, is the lower O-ring needed? I hope not. The upper one is fine.
Many thanks,
-Craig
Old May 1, 2005 | 09:45 AM
Car: 87 T/A
Well, nevermind. I discovered that the internal of the block must be modified with chamfered bores if the O-rings are to be used.
Guess this is another case of 'if all else fails, read the instructions'!
Old May 1, 2005 | 10:31 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
I noticed the same thing with mine.
Also, are you running the 8366? Did you happen to notice if your rotor fit a bit loose on the shaft? On mine, it seemed like the locator tab deal was a bit too thin for the rotor, and it would turn slightly on the shaft when installed.
Old May 1, 2005 | 12:14 PM
Car: 87 T/A
Yes I am, and I noticed the same thing. I tweaked the tab a bit, and that seemed to help.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
gixxer92
May 18, 2017 11:20 AM
meeklay812
Oct 1, 2015 03:46 PM
Damon
Sep 26, 2015 04:29 PM
