Air
Old Aug 11, 2001 | 09:37 PM
GTA-Force's Avatar
Air
Where in the car does the car gather air so that it can be used in the combustion process?
I've done reading on how the internal combustion engine in general works, but there's never been any clear indication as to where the air supply for combustion comes from.
Pictures would be a major plus, since I match up what people display with my motor.
Thanks.
J
The only good is knowledge; the only evil is ignorance.
[This message has been edited by GTA-Force (edited August 11, 2001).]
Old Aug 11, 2001 | 09:42 PM
Andy89RS's Avatar
Do you mean where is a good location to put an intake for the engine? If you're looking for a high pressure area while the car is moving, right at the base of the windshield is one of the easier ones to draw air from. (cowl induction hoods draw from this low-speed / high pressure air) The other spot is as far to the front of the car as you can put a scoop, like the ram-air style that new 'birds use. (high-speed / low pressure air there) Or are you talking aobut where does a stock one draw in air? That would depend on the year / engine type...
Old Aug 11, 2001 | 09:49 PM
GTA-Force's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Andy89RS:
Or are you talking aobut where does a stock one draw in air? That would depend on the year / engine type...</font>
Yeah, that's it.
I have an 89 GTA, 350 TPI V8.
Old Aug 11, 2001 | 10:05 PM
JETHROIROC's Avatar
Right through the ductwork into the throttle body then plenum then runners then intake base then cylinder head intake ports then combustion chamber...It comes from everywhere around you... If you're breathing, it must be there... I'm having trouble understanding what you mean by "where does it come from".
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Aug 11, 2001 | 10:36 PM
iroc5speed's Avatar
look on your TPI plenium, and follow it to the front of the car. there is a black air box. this is where the air comes from(at least on tpi camaros)
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Old Aug 11, 2001 | 11:23 PM
GTA-Force's Avatar
<font face="Verdana, Arial" size="2">Originally posted by iroc5speed:
</font>
The TPI plenum, what is that? Is that the metal plate at the top of the engine that says "Tuned Port Injection"?
Old Aug 12, 2001 | 12:17 AM
Andy89RS's Avatar
I think on Firebirds the intake is different. The plate that says "Tuned Port Injection" is mounted on the top of the throttle body. forward of that you'll see a large rubber tube that bends to the right side of the car and then leads down into a large round canister. Inside that canister is the air filter and on the end of it will be the opening that air is drawn in from.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
