How do I adjust the rocker arms?
To adjust the rockers you tighten the nut on the rocker till there is no more endplay on the pushrod, and then you give it another 3/4 turn. and you do it in this order.
You set the motor to top dead center. ( Firing on number one )
You then can adjust the 1,2,5, and 7 intake valve rockers, and then you can adjust the number 1,3,4 and 8 exhaust rockers.
You then spin the motor 360 degrees so it is firing on number 6
you then can adjust 3,4,6 and 8 on the intake side and
number 2,5,6 and 7 on the exhaust side.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
