What would you do????
Old May 1, 2005 | 04:25 PM
90tagta's Avatar
Car: 1990 Trans Am GTA
Transmission: 5-Speed
The car is a 1990 305 5-speed trans am gta. This summer i am planning on redoing the engine and transmission. The best part is the whole rebuildis going to be a gift! If you had $2,000 to 2,500 to redo the engine alone what would you do to it. All opinions are open.
Old May 1, 2005 | 05:08 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
383 stroker
Old May 1, 2005 | 05:28 PM
laiky's Avatar
how about a new 350 short block with vortec heads and a holley vortec hsr (rumored to be on the way) or a vortec base and some high flow runners. then some slp headers.
Old May 1, 2005 | 05:58 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
A 383 would be great.
I myself would retain the TPI/305 and use a set of World SR Torquer 305 heads, headers, a cat back, 1.6 to 1 roller tip rockers from Comp, siamesed intake runners, and a "Big Mouth" lower plenum.
Maybe some high-po ignition parts (coil, module, etc.). An adjustable fuel psi regulator, and lots of tuning.
If you have only $2500, and you want a bigger engine, that doesn't leave much money for anything other than the motor. And with a change from 305 to 350 or 383, you may have to buy other tuning parts to bring it all together with the TPI, or switch over to a carb setup and that could cost even more.
I myself would retain the TPI. If my T/A had come with it, I would have changed the heads, and tuned with exhaust, headers, etc as I listed above.
My vote is to work with what you have. I didn't, and the amount of cash I spent going from the stock carbed LG-4 305 to a 355 with a performance Holley, was up near $4500.00 on the motor rebuild and carburation along with all the new carb linkage and other extras that were required.
