header good ground for neg battery cable?
Old Aug 11, 2001 | 05:09 PM
rezinn's Avatar
n/t
Old Aug 11, 2001 | 05:18 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
yes
Old Aug 12, 2001 | 10:04 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Yes its a good ground as far as connections go...
But its a bad spot to ground the cable because of heat. You will cook all the insulation off the cable and it will look like crap.
As the cable discolors and deterorates, so does the actual conection due to corrosion.
I always use the heads.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Aug 12, 2001 | 11:13 AM
Vader's Avatar
A header flange bolt/stud might be O.K., but the header tubes themselves might not pass the necessary current for a hot start, not to mention the heating of the copper wire.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
86Base
Aug 8, 2015 01:34 PM
