starter install
Old May 2, 2005 | 12:28 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
starter install
can the stock starter be installed without removing the Edelbrock TES header on the passenger side? also,...what connects to the small post with the little nut on it....I knwo the big post is for the battery and other wires. thanks _J
Old May 2, 2005 | 10:58 AM
CbrasTsteLkChk's Avatar
Car: '84 Camaro SC/ I-ROC Body Conversio
Engine: Rebuilt 350 5.7L, Edelbrock 750cfm
Transmission: Re-built 700-R4
Axle/Gears: Moser, 3.73
I dunno about Edelbrock headers but for my install of my starter with hooker headers i had to set the header in place and **** it back towards the fender, away from the motor, and slip the starter up in there. It was a pain in the a** IMO. That's why i got a smaller corvette starter to put on there and I have to do the same thing but it doesn't take as much time and effort.
Old May 2, 2005 | 11:02 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
In my car (83 L69, with the BIG oval Y-pipe) it fit fine. Wouldn't start the engine (10.4:1 400) worth a crap though.
I later changed to a CVR "mini-starter", which also fit fine, and spun the 400 about twice as fast as the Delco garbage ever spun the OE 305.
I have SLP headers now instead of the TES; the CVR fits with those too. Don't know about the stock POS with those. Don't plan on finding out.
Old May 2, 2005 | 11:07 AM
Car: 1987 GTA
yeah, but did the stock one fit in WITHOUT removing the headers? I already had it in there with the headers.....i just hope i don't hav eto pull the header to put it in. also, any ideas what the small terminal post on the back of the starter is for? next to the big terminal post.
Old May 2, 2005 | 11:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes. Fit fine.
You should have a couple of wires with big terminals. Those go on the big post. You will have one purple wire with a small terminal. I'll let you figure out where that one goes.
Old May 2, 2005 | 01:37 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The little signal wire connects to the little allen head cap screw.
Old May 2, 2005 | 01:41 PM
ratchet wrench worked best for me to tighten those little bad boys up, due to the lack of clearence to get a socket up in there between it and the header pipes.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
milk
Aug 10, 2015 06:26 PM
