NO Power To FUEL PUMP.
Old May 2, 2005 | 07:35 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Transmission: T56/B&M/Ls7
I was driving along yesterday and the car started to sputter out and died....After 5 minutes it started back up and ran fine. Then pulling up to a stoplight it died again and would never start again so it was time to call the FLatbed....
Anyways, after inspecting it when i got home...the float boals on my carb are not filling up and no noise of a priming fuel pump....I've had this problem once before and it was the oil pressure switch, replaced it and it worked but I wouldn't think it would be that again....So i pulled the fuel pump harness near the tank and it is not getting power....I then replaced the fuel pump relay but no change.....What do I do next.
BTW...Inline fuse is also good...how do i check the oil pressure switch?
Thanks,
25thredrs
Old May 2, 2005 | 08:14 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
i had a similar problem when i switched to carb
I had to plug in the hei from the distributor to get fuel pump power.
when you pull the relay do you have the power in from the cpu?
If you don't i would check the connection at the dist
Old May 3, 2005 | 01:46 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
I'm not running HEI, I'm running an MSD pro billet distributor with a blaster II coil.
Old May 3, 2005 | 03:44 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
i am running a malory dist with a 6al msd and a msd blaster2 coil
Old May 3, 2005 | 03:52 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Third Generation F-Bodies > Tech Boards > Tech / General Engine > car doesnt run right and im poor with 1 car
see this thread and it will show you what terminals to check for power to the fuel pump.
Old May 3, 2005 | 05:21 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
SO what do i do..just run a hot wire from the battery to terminal G?.....but i dont think my relay looks like that.
Old May 3, 2005 | 05:28 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Nevermind.....where do I find the ALDL?
Old May 3, 2005 | 09:03 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
under the dash
what i am saying if you test that and your not getting power to the fuel pump relay. what is giving your relay the power?
Old May 3, 2005 | 09:08 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I have a hot wire running under my carpet to the wire under the back seats.
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
