Yet another 400 SBC cam selection question...
Old May 2, 2005 | 09:47 PM
Jeremysyty's Avatar
I have 4 bolt main 400 SBC stock crank, 5.7 rods, KB Hyp. pistons 3970126 72cc heavily ported heads, with 2.02/1.60 valves, Edelbrock RPM Performer intake, Holley 750 double pumper without choke assembly etc. 1.6 aluminum full roller rockers.
Behind the motor is WC-T5.
I am going to be going to open road course track days in the car. The motor was one I had from another car. Bought the TA for a steal without motor. Probably not the most optimal motor for road course.
So my question is what cam would be optimal. I found info the stock heads without porting and 1.94/1.5 valves flowed approx. 150 int./90 ex.
What would the optimal max RPM? Now I will be beating the hell out of the car. I am definitely not wanting a 7000 RPM.
Old May 3, 2005 | 10:02 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
Do you know if the person who did the heads put in valvesprings that can do 7000rpm?
You might be replacing the whole valvetrain.
Is this for street at all?
I don't have any answers for you, but before some of the xspurts get on here this is some of the stuff they'll want to know.
Old May 3, 2005 | 10:51 AM
Jeremysyty's Avatar
The valve springs are for a 400'ish lift cam. Redline was 4500 with the old setup. Figure those will have to be changed to fit the new cam.
C409
Sep 23, 2015 04:30 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
happyhapka
Aug 15, 2015 04:42 PM
