Porting heads
Old May 3, 2005 | 10:28 AM
violentgod1's Avatar
Car: 1989 RS
Engine: 305 ci v8 LO3
Transmission: WC T5
Porting heads
its just that. i just wanna know how to port heads or if i could even do it. I have the heads of my old LO3 and there still in good condition and i have my 92 with an LO3 so was thinking i could do that and just swap them. Thanks
Old May 3, 2005 | 11:04 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Step 1: Throw those heads away. Get some other heads besides L03 heads. Swirl-ports are the poorest candidates that there are for porting. THe best ones to get for the situation at hand, would be the ones from a 87-up LG4, L69, or LB9. Casting # 081.
Step 2: Visit http://www.sa-motorsports.com/portdiy/diyport.pdf and memorize it. Although, I personally suggest concentrating on the "bowl" areas right behind the valves first; as that's where most of the flow payoff is. Gasket matching and port enlargement are mostly useless at best and can actually reduce engine power, unless the bowls are maximized first.
MoJoe
Sep 24, 2015 09:12 PM
italiano67
Aug 31, 2015 06:04 PM
Brendankup
Aug 30, 2015 01:46 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
86White_T/A305
Aug 17, 2015 12:16 AM
