Bogging Down
Old May 3, 2005 | 12:54 PM
krumb's Avatar
Car: 92 RS 25th Anniv.
Bogging Down
My 305 tbi w/ 149k will not run WOT. I changed the fuel pump about six mths. ago and today I changed the dist.cap,rotor button, plugs,plug wires,fuel filter,PVC valve,air filter,breather filter w/ NO effect.When driving around town it runs good but when I increase the speed say like gettung on the freeway it falls flat on it's ***.The is all original stock. Could it be the injectors or the cat. Thanks
Old May 7, 2005 | 10:07 AM
Vader's Avatar
Hesitation on throttle tip-in and WOT is frequently a symptom of lean fuel mixture. Low pressure, filter restriction, and dirty injectors could be a cause.
Old May 7, 2005 | 04:15 PM
krumb's Avatar
thanks for the reply vader I was beginning to think no one cares. I to thought it had something to do w/ the fuel.The fuel pump was replaced 6 mths. ago,fuel filter about three yrs. when i removed the breather I noticed fuel up on top of 1 of the injectors what would cause this,also when driving below 50 or so the car runs fine but when I open up the throttle it kicks into low drive and loses speed.
Old May 7, 2005 | 04:19 PM
krumb's Avatar
What would be a good engine to replace the 305 w/ any suggestions
Old May 7, 2005 | 06:40 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
LT1!!!! All the way
Old May 8, 2005 | 07:52 PM
krumb's Avatar
thanks RamAIr21 I will keep that in mind when time comes
pjsparts
Oct 29, 2025 06:39 PM
RedLeader289
May 28, 2019 01:47 PM
Infested
May 22, 2018 11:56 PM
Grant2k
Apr 4, 2016 08:21 AM
middian
Sep 5, 2015 01:42 AM
