Updating a 305
Old Aug 13, 2001 | 09:31 AM
john fin's Avatar
Updating a 305
I have a blown 305 in a 85' Transam and I would like to replace it with another 305 but I would like the new engine to have a holley carb, no egr system or o2 sensor, and headers. By doing this conversion will it screw up the ECM and will the existing HEI work. The purpose of keeping the 305 is that I would have an extra set of heads in addition to everything else matching like the cam/distributor. Guess I would have to disconnect the engine service light if I did the conversion.
Old Aug 13, 2001 | 10:09 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The only thing you have to worry about is making sure you run a NON Computer controlled dist. with a holley carb.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 13, 2001 | 01:27 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Why the Holly over the Quadrojet? I thought those were pretty good carbs.
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
Stryker412
Sep 7, 2015 09:11 AM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
