Wont crank with the plugs in.
Old May 3, 2005 | 05:39 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
With the plugs out it free- wheels easily. I dont know whats up, compreession SHOULD be 9.7:1. New starter and battery. I checked the lash twice. Ive been building engines for a few years, and my racing buddy has been building em for 20+. We are both stumped.
Trick flow 190 heads, with a trick flow cam. 1.5 RR
TRW flat tops Eagle rods.
Old May 3, 2005 | 06:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
As in, won't even try to turn? Not even 90 degrees crank rotation?
Old May 3, 2005 | 07:40 PM
Transmission: th350
It will crank till a cylinder comes up to compression stroke. EVen if i take em all out but one plug it will crank till THAT cylinder comes around to compression stroke. Im thinking its the jumper cables i have rigged up to the starter arnt provideing enough amperage. The engine is on a start up stand, with no tranny attached.
Old May 3, 2005 | 08:32 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
She ain't got the power cap'n! Get some thicker cables and/or a more powerful jump box or battery....
Old May 3, 2005 | 08:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you trying to fire it? How much advance have you got?
Old May 5, 2005 | 06:02 AM
Transmission: th350
Good set of cables and it fire'd right up. *** im a dumb *** sometimes.
Old May 5, 2005 | 10:46 AM
five7kid's Avatar
Your secret is safe with us...
Cornholio7979
Sep 20, 2018 02:31 AM
gixxer92
Sep 1, 2015 04:32 PM
Winchester1094
Aug 18, 2015 10:23 AM
onebadazzsrt
Aug 15, 2015 07:00 AM
