My waterpump and its heater hose...lack there of
Old Aug 11, 2001 | 09:42 PM
GeneralGrant's Avatar
On my water pump the opening for the heater hose is pluged and sealed... Why? In looking through my chilton the diagram shows the heater hose being attached to the pump on my car the only thing that i think is the heater hose gets sent right back into the engine right under the intake. WHats gives?
Old Aug 11, 2001 | 10:00 PM
dtpmike's Avatar
yeah i noticed that also. The earlier years used a heater hose from the water pump as to feed the heater, no it uses a hose off the radiator hose on the side.
So does your heat work now or not?
Old Aug 11, 2001 | 10:17 PM
Being that its summer and i just bought the car I really dont know. I guess thats something to go check. How do i locate the heater hose? its not in the chelton. I think its getting redirected back into the engine but im not even sure if thats the right hose...
Old Aug 12, 2001 | 12:29 AM
Andy89RS's Avatar
That diagram is for early models. Later years didn't use that port so it was simply plugged instead of designing a new water pump housing. The heater hose should be coming off the passenger side radiator tank a few inches below the cap.
Old Aug 12, 2001 | 05:05 PM
What should it be for my 86 trans am? (tpi)
Old Aug 12, 2001 | 07:23 PM
Vader's Avatar
Ulysses,
My '86 Trans Am TeePee Eye has the return hose from the heater core. There is also no hot water valve on the pre-1988 cars, so you get hot water to the core all the time. Personally, I like that so sediment doesn't rot out the core all summer long. I have the black shiney heater hose pointed right at the back ot the alternator:
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 13, 2001 | 07:53 PM
So vader yours goes to the waterpump and not the radiator?
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Formula8r89
Sep 22, 2015 04:24 PM
