reassembling heads-lube question
Old May 4, 2005 | 12:33 PM
Cole's Avatar
I'm reassembling my cylander heads with the original parts. In my haynes book it says to lube up the rocker pivots and valve guides with moly grease. Is this just if using new parts for break in? Should I use moly or just oil the parts up? Thanks.
Old May 4, 2005 | 01:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Oil is fine for the valve guides. Moly would be a good choice for the rocker *****, when you get to that point.
Old May 4, 2005 | 03:35 PM
ede's Avatar
ede
any more i use the red oil like assembly lube for rocker *****
Old May 4, 2005 | 05:09 PM
Cole's Avatar
Ede, do you use anything on the valve guides? I've already installed the valves, seals, springs, etc. The valve stems have a light layer of oil on them from when I oiled them to slide the seals on, but that's it. What keeps them from burning up? Thanks again.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
