timing question
Old Aug 13, 2001 | 10:31 AM
ihateallmustangs's Avatar
timing question
how do u adjust the timing on an 89 rs 305 tbi?
Old Aug 13, 2001 | 06:37 PM
Andy89RS's Avatar
Warm engine to normal operating temp. Disconnect the brown EST wire sticking out of the harness in front of the blower motor. Loosen distributor hold down. Start engine and check timing. Stock is 0*, most people are running around 4-6* BTDC on LO3's, you'll have to experiment to find what's best for you. Once you have the timing you want, snug the hold down bolt and make sure the EST wire is reconnected.
Old Aug 13, 2001 | 10:32 PM
iroc5speed's Avatar
go buy a timing light and have someone show you how to use it, and then do as andy said.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
