Code 32 V6 Changed EGR Still Code 32
Old Aug 12, 2001 | 09:11 PM
86project's Avatar
Does anyone have an idea?......
Service Engine light randomly goes on and off after driving the car about 10 minutes. Pulled the code and got a #32...EGR system. I have a rough idle and slight hesitation on acceleration. Sounds like the EGR valve. Put a new valve on, , reset the computer,drove the car, light came on again. A code 32 again, checked every hose for a leak and found nothing. I did a vacuum test 15 inches at idle, 18 at 2500 rpm or so. Can't find the problem. Anybody have an idea? I would greatly appreciate it.
86 project
2.8 v6 bone stock for now
Old Aug 13, 2001 | 04:25 PM
Reagan's Avatar
i have a '91 5.0 with the exact same problem, sorry i can't help, but i hope someone can
Old Aug 13, 2001 | 06:14 PM
Eddie's Avatar
Have you checked the EGR valve solenoid? It is a small electrical component that controls the EGR valve, check where the lines from the EGR valve go and you will see it back there right next to the EGR valve(on v8) by the distributor, has (1) electrical connection and (2) vacuum lines.
Old Aug 13, 2001 | 10:43 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
Changed the egr switch on my 350 tpi and got rid of the light. It shouldn't be causing idle problems though, try cleaning the throttle body with a can of gumout carb cleaner,for the rough idle.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
