Bought my second thirdgen today :)
Old Aug 12, 2001 | 05:53 PM
UVA3rdGen's Avatar
89 IROC with 350 fully loaded T-Tops(with GM recall fix) original owner with 130k for 4 grand. Paint looked new and had tons of new parts. I think I got a pretty good deal. Tech question time:
With that many miles do you think I will need to replace the fuel injectors and fuel pump anytime soon?
Old Aug 12, 2001 | 06:27 PM
iroc5speed's Avatar
from what I understand you don't need to change the injectors ever, you can just get the system cleaned. BUT, if I were you, I'd wait until I did some mods, then get higher injectors and a better pump.
Old Aug 13, 2001 | 09:19 AM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
UVA3rdgen,
My '89 has the original injectors at 180,000 miles, but the original fuel pump only made it to 167,000 miles.
BTW, what's the GM recall fix you are talking about with the T-tops?
[This message has been edited by 89Z (edited August 13, 2001).]
Old Aug 13, 2001 | 09:06 PM
Chevy83Z28's Avatar
Somtehing that should be changed at that high of mileage would be the timing chain I'm thinking? (unless of course if it was already changed.)
Old Aug 13, 2001 | 10:06 PM
UVA3rdGen's Avatar
I was just thinking about that. He had fixed so much I figure it was already done. I did not even know a motor could go that long with out it being changed. But diffinitely if it has not been done that is one of the first priorities.
Old Aug 14, 2001 | 09:01 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
About that recall fix?
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86IROC112
Sep 7, 2015 01:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Exxon Limited
Aug 9, 2015 08:13 PM
