passenger side header glowing?
Old May 5, 2005 | 10:35 PM
IROCBlueZ28's Avatar
OK, got my new tranny in and took my Z out for a spin. I ran 3 good hard runs giving 8psi. Drove it right home into the garage. I turned off the lights, opened the hood and noticed my passengers side header collector was glowing red. The header was glowing red at the collector after hard excelleration.
WHY?
It was not red on the drivers side, but it was on the collector where it mates to the Y pipe? Any ideas? Timing is set at 8deg. advanced, just replaced the IAC, no codes.
Old May 6, 2005 | 06:47 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
You have a lean mixture.
A wide band A/F meter is an invaluable tool. With the set up you have, I highly recommend getting one. Innovate Motorsports has an affordable unit.
Good luck.
www.geocities.com/dzperf
Old May 6, 2005 | 09:12 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I'd also check for exhaust leaks at all connections near the engine.
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Wesly_66
Aug 26, 2015 09:55 PM
Cameeeero
Aug 20, 2015 03:06 AM
Street Lethal
Aug 14, 2015 08:25 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
