Mechanical speedo bounces
When I'm going about 70-75 mph, the speedo starts bouncing from around 60-65 to around 90-95. I can also hear what sounds like some sort of scratching/sqeaking coming fromthe speedo. This problem is clearly mechanical, as it's an 89 Iroc cluster.
I've searched and found some people suggesting the cable needs lubing, which I'll do just in case, but the sound makes me wonder if the speedo internals are just plain worn out.
Any thoughts or suggestions?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It sounds like the cable. If the bouncing was worse and made more of a ringing sound, then the head would need to be rebuilt.
sjorgens
Oct 1, 2015 07:54 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
