Where can I buy replacement ACDelco parts?
Old Aug 14, 2001 | 11:08 AM
maksik7's Avatar
IF somebody could point me to a site or tell me where I can get them (any GM dealer right?) I would appreciate it.
I need a TB Gasket set, an IAC valve and something else which I have forgotten at the moment.
Thanks for the help,
-Max
Old Aug 14, 2001 | 11:26 AM
manuel's Avatar
hey man!!!
I can tell you that you don't have to goto a stupid dealer for a stupid gasket and crap.
IF you have a Autozone in your area,check them out or at www.autozone.com
Seach the catalog for a throttle body kit.
They have everything you need in that kit.It will cost less than a stupid dealer for a gasket.
Old Aug 14, 2001 | 11:28 AM
manuel's Avatar
<font face="Verdana, Arial" size="2">Originally posted by manuel:
hey man!!!
</font>
o yeah.the parts are :
Idle Air control valve (IAc)
Manifold absolute pressure (MAP)
Throttle position sensor(TPS)
Fuel injectors(2)if TBi
THrottle Bosy gasket.
Old Aug 14, 2001 | 02:39 PM
R.O.B.'s Avatar
Autozone is a good source, so is: www.napaonline.com
www.partsamerica.com
As for GM dealers/parts, try:
www.gmpart.com
www.gmpartsdirect.com
www.paceparts.com
www.auto-parts-for-less.com
www.spoperformanceparts.com
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Old Aug 14, 2001 | 10:47 PM
calroc's Avatar
If all those aren't enough, try www.acdelco.com or call 1-800-223-3526
ChevyZ71
Aug 13, 2015 07:30 AM
Zachattack0925
Aug 12, 2015 09:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
MENINBLK
Aug 5, 2015 11:58 PM
