Quick question
Old Aug 14, 2001 | 08:43 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Quick question
Is the A/C pressure switch normally open or closed is there is no line pressure ?
Old Aug 14, 2001 | 08:49 PM
agawam's Avatar
closed ...If you take a jumper wire and connect the two plug-ins on the connector the compressor clutch will engage
Old Aug 14, 2001 | 08:56 PM
deadbird's Avatar
Engine: TPI 305/ v6
I thought the press switch was for the fan ?
closed works for me though, thanks.
Old Aug 15, 2001 | 10:56 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
There are three switches on the ac system. Two mount to the lines, these control the compressor. The plug that goes into the top/rear of the compressor is for the secondary cooling fan.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
