EGR and pollution controls *PICS*
Old May 7, 2005 | 09:24 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
ok im doing and engine swap, and lets say, no egr, ever again. so anyways is that box(with the dot) part of the egr (im 90% sure it is)
and the new intake is non egr, and there isnt spots for things from the old manifold, like a few electrical conections and for the thing with the arrow pointing to it.(there is another part to that is metal kinda like a fuel line)
and im sure this is pollution controls, but someone told me its worth money and i have two of them (one from a parts car.)
Old May 7, 2005 | 09:46 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Holy crap! You don't know what the thing with the arrow is but your doing a motor swap?
You will NEED that line - it's the brake vac line - and a must unless you plan on switching the entire brake system. The "Box with the dot" doesn't deal with the egr, but it is emission's related. If you are running EFI, you will need to correct your bin for removing that... it is part of the A.I.R. system that puts fresh air into the exhuast for emission's reasons. The ECM is set to read with that O2 in the system when the ECM signals for it too be there, so not having it may cause your AF ratio to be off slightly.
Old May 7, 2005 | 10:01 PM
Borsty's Avatar
Car: 89 Trans am
i knew it was a brake vac line, but their isnt a new spot for it on the new intake.
Old May 7, 2005 | 10:20 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
The brake booster line should be connected to a source of constant manifold vaccum. If there is not a connection on your new intake manifold for it, make one. I drilled and tapped a connection in my manifold when I put in my Holley.
Old May 7, 2005 | 11:53 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
In the second one, it looks like the charcoal canister and the cruise control.
Which one are you talking about?+
Old May 8, 2005 | 01:58 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
On my Vortec Air Gap manifold, I put a T on an existing hole rather than drill/tap a hole. See the picture circled in red:
Old May 8, 2005 | 03:50 AM
Borsty's Avatar
Car: 89 Trans am
canister steve.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Kenwood
Sep 11, 2015 12:50 PM
dbrochard
Sep 7, 2015 09:41 AM
rjcme
Sep 5, 2015 01:23 PM
