booyah!
Old Aug 14, 2001 | 09:35 PM
rezinn's Avatar
booyah!
Car started up, holy **** does it sound mean. I still need to break in my new cam, but the car won't run on its own because I can't find my distributor wrench to fix the timing(oops, damnit). I put the distributor in 180 degrees off and it backfired on me, so I tried to take it out but that was a no go without a distributor wrench, but.. putting all of the spark plug wires on backwards(1 where 6 goes, etc) did allow it to start. Just FYI I can't wait to get this baby on the street and to the track.
One question.. the third throttle cable(lowest, outside) on the throttle body. What is it? It comes from around the charcoal canister.. Is it supposed to hang loose with the engine off? Mine has a bit of slack, but I didn't check it running since the car doesn't really run yet.
Old Aug 14, 2001 | 09:47 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Good job on getting the car running!!!
That third cable is for your cruise control =)
Kat
Old Aug 14, 2001 | 10:20 PM
rezinn's Avatar
Oh screw that! I never use that "cruise control" crap you speak of! Thanks man.
Old Aug 15, 2001 | 06:55 AM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Good job on getting the car running. Way to go man!
Later
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Aug 15, 2001 | 08:00 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why did you tighten your dist down before setting timing?
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
And good deal on the new motor!
Old Aug 15, 2001 | 10:27 PM
rezinn's Avatar
Because Im an idiot, Duh! I still can't see the timing mark, but Im being nice to my neighbors and not starting it up tonight.
3rdBird
Northern California
Oct 8, 2008 11:34 PM
booyah
Apr 25, 2006 09:41 AM
