clutch fan?
Old May 9, 2005 | 11:12 AM
leeski's Avatar
Car: '82 Berlinnetta
Engine: Modified 350
Transmission: Turbo 350
clutch fan?
Took the car out yesterday, slowly heated up to about 240 degrees and I took her home. With everything warmed up, I shouldn't be able to spin the fan easily by hand, should I? It's a thermal clutch.
Old May 9, 2005 | 01:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The clutch is supposed to get stiffer but not completely lock up when hot air comes through the rad.
Old May 9, 2005 | 01:24 PM
leeski's Avatar
How do you tell if it is bad, then? Try a new one and go? Like I said, it spun pretty easy by hand.
Old May 9, 2005 | 01:42 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Maybe time to convert to an electric fan. It'll free up a few HP as well.
It was easy to tel when the one in my 84 Z28 went bad - it was leaking it's fluid from the seal around the shaft.
Old May 9, 2005 | 01:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could try popping the outer end of the bimetal spring out of the clip and check how much stiffer the clutch gets when you twist the center shaft to its limit in either direction. I don't know if that would actually be useful or not. Usually if there's any question if it's good or not it needs to be replaced.
BrianI
Oct 3, 2015 12:57 PM
z28joe2
Sep 28, 2015 05:54 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
