Torque specs
Old Aug 16, 2001 | 03:03 PM
sb406camaro86's Avatar
Car: chevy s10,1986camaro
Engine: 406sbc
Transmission: 350turbo
Torque specs
Should I use the same torque spec for a cast iron intake on an aluminun one for the carb studs? If not what should I torque the studs down to? Just finished putting helicoils in two of the bolt holes. Don't want to have to do it again, so any help u can give me would be a big help.
406SBC
-DART SPORTSMAN 2 HEADS
-RPM INTAKE
-750 SPEED DEMON MECH SEC. CARB
-HEDMAN HEADERS
-COMP CAM EX .507/.510
-1.6 roller rockers
-th350 tranny
-posi rear disc
Old Aug 16, 2001 | 03:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No need to even torque them, really. They just need to be in there tight enough that they won't back out when you loosen the nut. 10 ft-lbs ought to do it. If you're using bolts instead of studs you would probably want a bit more, maybe in the 12-20 ft-lbs range, depending on the gasket you were using. That's also about what the nuts would need.
ICON Motorsports
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
