Why is my L03 getting 200 miles to a tank?
Old May 10, 2005 | 07:09 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Ok, my car is really making me mad. I had noticed that the gas mileage was getting worse so I decided to check it. I only got 200 miles on my last tank. I ran mid-grade as usual. I haven't been running it hard, either. In addition to the terrible gas mileage, it has lost some power. That is not a good thing.
It is getting about 15 miles per gallon. Before, it got a little over 20 on average. Can someone tell me what I can do to fix it?
Old May 10, 2005 | 07:50 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Tuneup and O2 sensor for starters..
Old May 10, 2005 | 07:56 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I thought about that, but I wasn't sure if it would help. I had a tune up recently. Come to think of it, that is when all this started. Looks like a real tune up is in order. Need to get the O2 sensor, as well. I don't know.... you may just be saying that to keep my car running crappy .... You do drive a GT.
Could my fuel pressure regulator have anything to do with it? A friend of mine mentioned this. I didn't know if it had anything to do with it. Are there any more sensors that can go bad? The air temperature sensor in the breather, maybe?
Old May 10, 2005 | 09:09 AM
Nixon1's Avatar
If your FPR ruptured a diaphragm or something, sure it could be a problem. Check your fuel pressure with a gauge....with the FPR vacuum-line connected, then remove it and look for pressure to go up around, say, 5 psi or so. That means it's working properly.
As far as the other sensors, I don't know of a real way to test them. IAT doesn't usually go bad so I wouldn't count on that one....
And btw, I own a GT now but I used to have a 91 RS. If I didn't still like the cars, I wouldn't be here now would I?
Old May 10, 2005 | 10:04 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You need a tune up. I would bet the house that your 02 is shot. A bad 02 will not suplly the correct voltage to the ECM to make fuel adjustments.
Old May 10, 2005 | 02:34 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Thanks for the help. I will try this and see what I get. BTW, I hope the O2 sensor is still good.
I know. I was giving you a hard time about the Mustang.
Old May 10, 2005 | 02:47 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
That's all I ever got on my L03. I bought it @ 155,000 or so and I'd be amazed to get 210 miles/tank. I looked everywhere and could only find the Bosch O2; wanted Delco. In hindsight, I should've looked harder. From analyzing my WinALDL logs I'm convinced the Bosch is total crap, but better than the old sensor in any case.
Jake_92RS
Jan 28, 2020 10:37 PM
chazman
Aug 28, 2018 03:25 PM
LT1Formula
Nov 16, 2015 01:13 PM
chazman
Aug 22, 2015 02:01 PM
