Spark plug wire size
Old May 10, 2005 | 05:29 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
On a stock ignition driving bolt ons, do 8.5 mm wires really help that much over stock 8 mm ones?
Old May 10, 2005 | 06:00 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Not without more voltage from a hotter coil, but they sure look
cooler.....
Old May 10, 2005 | 06:33 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
OEM is either 6mm or 7mm
but no, you won't notice any difference. however, if it's time to replace them, it can't hurt to spend the extra $5 and get a bigger set.
Old May 10, 2005 | 07:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You may notice a slight increase in your MPG but that is about it. One of the main reasons for aftermarket wires is for radio interference supression.
Old May 11, 2005 | 02:20 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
No, you won't.
Old May 11, 2005 | 02:42 AM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
Got accel 8 mm ones.
Old May 11, 2005 | 10:31 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
i measured the impedence on a stock wire and again on an accel 8.8mm. the stock wire had almost ten times the resistance. is there a difference between stock and 8+mm wires? without a doubt. will you notice any difference between 8mm and 8.5mm. very doubtful.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
