Rotor Replacement help quick!
Old May 11, 2005 | 01:57 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
How do you get the rotor off the car? it doesnt have any screws or anything and its on there pretty tight.
Old May 11, 2005 | 02:05 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
https://www.thirdgen.org/newdesign/tech/brakes.shtml
Old May 11, 2005 | 02:10 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
As in ignition rotor under the cap, sorry for the generalization.
Old May 11, 2005 | 02:11 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I assumed he meant Distributor "Rotor". If it is a V8 there are screws, 2 on top.
Old May 11, 2005 | 02:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The '87-up small cap rotors were push-on types.
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
brakes
I don't think it's one of those!!!
They get stuck all the time. Just blow it away somehow; set off a grenade in the distributor, whatever. Just don't bend the shaft.
Put a little of that dielectric grease on the shaft before you put the new one on; it will prevent that from happening again.
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Winchester1094
Aug 18, 2015 10:23 AM
