Timing question
Old May 12, 2005 | 09:06 AM
NML98TA's Avatar
Car: 1989 formula 350
Timing question
I put a new L98 in my 89 TA, and when I was messing with the timing I noticed that When I hit the throttle the timing retards about 10-12 degrees. I was wondering if that was normal. I figured that as the rpms went up the timing would advance. I put a new knock sensor on it and ot still does the same thing.
Old May 12, 2005 | 10:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
With the ECM connected, timing will be more advanced at idle/no-load than when you hit the throttle. Just like the "old days" with a vacuum/mechanical advance distributor, when vacuum goes down (like when you hit the throttle), advance goes down.
For the record: The timing is "set" with the ECM wire disconnected. That is the "base" timing. Anything you do with the timing light after that is for amusement purposes only.
Old May 12, 2005 | 10:49 AM
NML98TA's Avatar
I had the ecm disconnected
Old May 12, 2005 | 10:56 AM
five7kid's Avatar
How certain of that are you?
With the ECM disconnected, the "limp home mode" will advance with RPMs only, from what I've seen & heard.
Old May 12, 2005 | 11:00 AM
NML98TA's Avatar
To set the static timing you disconnect the brown and white wire on the passenger side of the car over by the heaterbox. So that's what I did.
Old May 12, 2005 | 11:03 AM
five7kid's Avatar
Okay, I'll let someone else chime in then. If it was retarding that much, then it would have been ATDC as you blipped the throttle.
Old May 12, 2005 | 11:05 AM
NML98TA's Avatar
This may be a dumb question and I'll probably feel pretty stupid when you answer it but what is the ATDC?
Old May 12, 2005 | 11:11 AM
NML98TA's Avatar
Stupid me after top dead center. Had a brain fart temporarily.
Old May 12, 2005 | 12:01 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
What RPM was it at and how high did you rev it?
Old May 12, 2005 | 12:03 PM
NML98TA's Avatar
I set the timing at about 900-1000 rpms, and I reved it to about 3500.
Old May 12, 2005 | 01:06 PM
kevinc's Avatar
Car: 1982 Z28
With the ECM disconnected, the engine won't even start or run.
Maybe you had just the EST disconnected?
I wouldn't waste time troubleshooting w/ EST open, just hook it up and run it w/ a scanner attached to verify correct operation.
Old May 12, 2005 | 01:08 PM
NML98TA's Avatar
2 questions
A: where do I get a scanner and
B: It will tell me if the timing is correct.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
