Rear Axle Problem
Old Aug 17, 2001 | 11:08 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Rear Axle Problem
Well I Have A Bent Axle On My 88' 9 Bolt Borg Warner Rear End. Well What Would You Guys Recommend. Replacing The Axle Shaft? Is It Too Much Work Or Even Worth It? Take In To Account That I Have No Experince With Rear Ends. Or Pull A Newer Rear End? If So What Year and Type. 10 bolt? My Rear Brakes are non-functioning As well. Thanks In Advance. All Suggestions Are Welcome
88' IROC-Z, 350 TPI, 700-R4
Old Aug 18, 2001 | 09:12 AM
ede's Avatar
ede
change the bent axle, it's way easier than swapping in a new rear end. only takes a few tools and very little skill. look in a manual to see how it's done if you aren't sure.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 18, 2001 | 09:24 AM
Vader's Avatar
Mystik,
Ed is correct, and changing an axle on a Borg rear is easier than the Saginaw units, since you don't have a circlip in the housing to remove. Just remove the wheel, brake, and bearing plate from the outer end of the axle and slide the axle assembly out.
Since you may have some difficulty finding a replacement shaft for your Borg axle, you could check with a larger electric motor rewind/repair shop to have the existing axle straightened and balanced. They have the equipment to straighten and balance heat treated shafts like an axle.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 18, 2001 | 09:55 AM
Car: 1988 IROC-Z
That's sounds cheaper than another rear end.
Let's See if i can find a larger electric motor rewind/repair shop around here. If I Run Into Trouble I'll Post Again. Thanks Guys For The Advice.
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
