Rotor
Old May 13, 2005 | 12:08 PM
Dubkor's Avatar
Car: 1986 Firebird
Engine: 2.8 LB8
Rotor
This may make me look like a bit of an idiot, but I have the distributor cap off my 1986 Firebird, but damned if I can figure out how to pull off the rotor. It's on there pretty solid, but I can't see any screws or whatnot that would hold it in to place, and certainly nothing on my replacement that would do the same thing.
Any ideas?
Old May 13, 2005 | 12:33 PM
allsound's Avatar
Car: 1987 Camaro Z28
Engine: 305 carb for now
Transmission: 5 speed
I found when I had to take mine appart it was just a matter of force an lube if somehow you can get that in there. I remember having the exact same problem, I had to get someone to show me how to just simply pull it off haha. Although when you put the new one on don't put it on too tight....when I did mine I hit it lightly (or so I thought) with a rubber mallot and it shattered. The guy at the store said he'd never seen anything like that ha!
Old May 13, 2005 | 12:44 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
My stocker was on there tight. Tap it upward with a hammer. It will come off eventually.
Old May 13, 2005 | 01:16 PM
Damon's Avatar
1986 V6 motor? Yeah, they just slide on. Of course they then do a mind-meld with the distributor shaft after a few years and often require quite a bit of force to get them to pop off. I coat the distributor shaft with a thin smear of grease before I drop the new one on. Then it'll pop off easy the next time.
Old May 13, 2005 | 03:49 PM
91V8Redbird's Avatar
Car: 91 V8 Firebird
Engine: LO3 305 TBI V8
Having the same problem with my 305 right now. I also noticed the top of the distributor was covered with surface rust. Is this normal and could it be causing the rotor to stick?
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
