87 tpi 350 timing marks
Old May 13, 2005 | 07:36 PM
sparks454's Avatar
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
On my '87 T/A 350 tpi should the timing marks be at the up and up position(12 and 12 o'clock)??? I have a new double roller set w/ the 3 keyway crank sprocket that I have not used yet. It's new but there are no instructions.
If it matters, with the marks in the 12 and 12 positions, the intake valve is still closing while the #1 piston is coming up. Visually it appears to working correctly though, but I wanted to make sure.
The cam is a comp cam 220/230 w/ .510" lift.
Old May 14, 2005 | 02:11 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Timing gears
cam-12 and crank-12 is correct for compression stroke, but when installing gears are easier to align when marks are facing each other; cam-6 and crank-12.
Old May 14, 2005 | 08:04 AM
sparks454's Avatar
Car: 1987 GTA
Thanks.
midge54
Dec 27, 2019 04:14 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Sanjay
Aug 12, 2015 03:41 PM
Thirim
Aug 9, 2015 06:19 PM
