New setup.
Car: 86 Firebird, 2002 Monte Carlo, 91 v
New setup.
Here's what I have. I have a 1979 350, 600 cfm carb, comp 270h-10, new lifters, new springs, new double roller timing chain, holley street dominator 300-38 intake, and a new holley mechanical fuel pump. Should I keep my 350 heads or switch to my 305 heads? About how much would this combo be worth as far as h.p. ?
Transmission: 4L80E/4L80E
What are the 350 heads, 882 castings? If so, probably go with the 305 heads, depending upon what they really are. So, what heads do you have?
There have been several posts recently about porting. Check them out.
If your heads are 416, 601, or 081, ported w/1.94" intake valves, with headers and decent exhaust you can expect a good 300+ HP.
heads no clue
whatever was stock on a 79 chevy van. Wasn't the original motor that was in it, but they said it came out of another 79 chevy van
Truck heads - not good for performance.
Go through your 305 heads (assuming they are the '86 LG4 or LB9 that came with the car).
LG4 = H (had a q-jet carb stock)
LB9 = F (had TPI fuel injection stock)
Available on the thirdgen.org homepage Tech Data link.
Car: 2002 Formula Firebird
Transmission: 4l60e
The lg4 heads have a lot of potential if they are ported. I say do a DIY port job on the 305 heads and put them on the motor. Chances are your 79 van motor has very low compression and terrible heads on it. Just about anything late 70's probably did.
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
Doobie52
Sep 11, 2015 06:19 PM
