Best Synthetic Oil?
Car: 1989 Iroc_Z
Best Synthetic Oil?
I am doing a oil change soon and switching to synthetic..I was thinking of going with Royal Purple..What are you guys running out there. What do you recommened?
I also heard with synthetic oyu loose a quart in between oil changes, whats up with that?
Re: Best Synthetic Oil?
There is absolutely no truth to your second statement. Oil consumption is no different between dino and synthetic oils. The only possible problem people have with synthetics, and where all these old mechanics tales come from, is people with ****ty maintenance have oil leaks all over there engine anyway, and over time the crap in their motor will plug these oil leaks. Synthetic Oils, however, do a much better job cleaning and lubricating, so they will get rid of the crap. This causes the leaks to reappear and the uniformed think the oil caused it, when in reality their engine is just old and tired. A properly maintained engine will have no trouble using synthetic oil.
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I would go for AMSOIL All they way. I heard really good things about it. Once i start to get little more money im going to get that for sure. Mobil 1 is also good. Both oils do a very good job
skinny z
Oct 5, 2015 06:23 PM
