Trying to seize an engine...would this work??
Engine: LH0 3.1L
Ok, i'm going to the junkyard tomorrow to attempt (again) to get a flywheel. Last time i couldn't jam something to stop the motor from spinning and i had no leverage.
So i've been thinking....what if i filled a cylinder with dirt and put the spark plug back in??? Would this keep the motor from spinning??? Any other suggestions? It's friekin hard to do this on while lying on my back.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
come one, I got mine off buy just jamming a screwdriver between the teeth of the flywheel and then use a breaker bar and smack it as hard as you can, you have to use a surge of force to break it loose when you can't hold it too well. If all eles fails, got get an impact gun with imapct sockets.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Take this post seriously: snap on makes a
battery powered impact gun.. At first I thought it was a joke, but I know a few guys at the garage now that are using them in place of their air powered guns and they work
very, very well.
-- Joe
very, very well.
-- Joe
Car: 92 Camaro RS
Engine: 305 TBI
Take out a sparkplug and thread a couple feet of 1/4" rope into it, when you turn the engine it will lock up when it compresses the rope.
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
T-Tops
3.08 Posi-trac
Crane cam
HyperTech Chip
Car: 89 IrocZ
Engine: L98-ish
There are inexpensive (read Asian) flywheel turners, looks kinda like a spanner wrench that graps the flywheel.
Cost about 10 or 12 bucks at the discount AP stored.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
<font face="Verdana, Arial" size="2">Originally posted by anesthes:
very, very well.
-- Joe</font>
very, very well.
-- Joe</font>
Car: 91 RS Convertible
Engine: 305 TBI
I don't know much about flywheels and it's been a long time since I've worked/seen one but......
Don't they have large holes in them??
If so, couldn't you just stick a pipe or piece of wood in one of the holes to jamb the flywheel?
Just a thought.
Just a thought.
NO, a flywheel does not have holes in it. A flexplate for an auto does.
Put a breaker bar on the nut on the crank and brace it against something that will not move. Thats what I do.
Also make sure you are using 6 pt sockets or you will round off the heads.
Dale
1986 FireBird
2.8L MPFI
Gutted Cat, No muffler (Sweet Sound)
Was 700-R4 --> Now T5
Dale
1986 FireBird
2.8L MPFI
Engine: LH0 3.1L
When Snap-On sells sockets for like $40 each, i can only imagine how much that impact would cost. Would be nice to have though. I'm off to the boneyard now.....
From: First one out of liberty city, burn it to the ground
Take a tie down and attach one end to the flexplate/flywheel other end to a fender or anywhere else
Slowly getting slower 1989 Firebird.. modded heavily for a v6
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
My Site:
Click Here to see my car!
#3 Forever
My Site:
Engine: LH0 3.1L
Yes!!
My plan worked. Except i used some old screws and nuts that i found. I threw them in the hole and JACKPOT....locked-up motor.
$20 for the flywheel. Not bad....needs to be resurfaced though.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
My plan worked. Except i used some old screws and nuts that i found. I threw them in the hole and JACKPOT....locked-up motor. $20 for the flywheel. Not bad....needs to be resurfaced though.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Engine: 305 TBI
Ahhh...hahaha!
Now I LIKE that one!!!
Good job my man!
Guess who ever buys the block is going to get a surprise when they take the heads off.
Good job my man!
Engine: LH0 3.1L
<font face="Verdana, Arial" size="2">Originally posted by sunbitz:
Ahhh...hahaha!
Good job my man!
</font>
Ahhh...hahaha!
Good job my man!
</font>
"No wonder this car was junked... It's got SCREWS in the combustion chamber!!!!"
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
colton_carlson
Mar 8, 2019 12:21 PM
