flicker flicker flicker
Old Aug 17, 2001 | 12:52 AM
zerogauge's Avatar
going down the highway and my lights start flickering and almost go out...the car stays running fine but all the electrical like goes out and my charge light(idiot style) comes on and then goes off. then the car starting backfiring through the carb(i think) under acceleration.
suggestions? motor is a 350 with a carb. pretty mild motor. this just happened kind of all of a sudden
Old Aug 17, 2001 | 09:34 AM
ATOMonkey's Avatar
Sounds like you have a loose ground somewhere. If the engine is backfiring like that the first ground I would check is the main ground off of the battery. Make sure that it is getting good connection.
[This message has been edited by ATOMonkey (edited August 17, 2001).]
Old Aug 17, 2001 | 10:39 AM
sleeper's Avatar
Also check for a loose alternator belt or a bad alternator.
Old Aug 17, 2001 | 10:42 AM
88 GTA Notchback's Avatar
Check you ground wires, connection to the alt. and if you still cant find anything..you may want to have your alt. tested.
Old Aug 17, 2001 | 12:38 PM
zerogauge's Avatar
all connections appear to be solid but the connection from the negative battery post to the header is pretty cached in oil i believe from a leaking valve cover gasket. going to clean that and see if it helps...all else fails guess I will take that alternator off
Old Aug 19, 2001 | 10:15 PM
Zero,
You can take your car to Advance Auto, Auto Zone, etc.. and they will test your alt. for you.
88 GTA Notchback
A4 / 350
Stock
** New User Name**
Kill List:
95 Mustang GT |88 Mustang GT
94? Impala (real close)|97 Dodge Neon
86 Corvette |2000 Prowler
88 ASC GTA | And a few more Accords and Neon's.
And more Civic's then I can count. Why do they even bother?
1992CamaroGirl
Dec 25, 2017 08:45 PM
billsfirebird
Jan 19, 2002 05:22 PM
89GTA5spd
Feb 8, 2001 07:12 PM
87/88Firetruck
Jan 31, 2001 05:10 PM
