Stupid balancer!
Old Aug 19, 2001 | 10:59 PM
Digger's Avatar
Stupid balancer!
Last night i pull into my drive way hit the gas pedal a little and the balancer flies off. I got looking and the bolt has been broken off(I think since i have owned my car) The balancer has been cracked on the key way for a while it looks like. But what I want to know is the crank screwed? the key way looks not bad and there are no visible scores on the crank. So how will I know if something is screwed up.
Old Aug 19, 2001 | 11:35 PM
burnoutrpm's Avatar
yeah i had similar experience except mine was stuck ON with red locktite, turned out the guy before me put a HEAD BOLT in the crank of course we couldnt get all of the bolt and just put red locktite on it this sucked!!!
89 firebird formula
360 10:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1405edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!.with lots of NOS
Old Aug 20, 2001 | 12:40 AM
Vader's Avatar
Digger,
You'll know if the crank is "screwed" when you mic it or try to install a new balancer hub.
Later,
Vader
"Get UP - Drop the bombshell!"
Adobe Acrobat Reader
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
monte87cortez
Sep 26, 2015 08:10 PM
83ho87gn
Sep 24, 2015 08:58 AM
Magman
Sep 13, 2015 12:14 AM
