installing posi, is there a difference between carriers?
Old Aug 20, 2001 | 08:09 AM
BlackZee's Avatar
I have a 342 open rearend and have access to a 273 posi unit. Can I take the posi out of the 273 rear and install into my 342 rear? Thanks in advance for the help!
Old Aug 20, 2001 | 08:20 AM
82camaro's Avatar
Car: 82 camaro SC
3.42 is a 3 series and 2.73 is a 2 series. You can't interchange carriers with the stock gears.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 20, 2001 | 08:57 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
You will also need to verify number of splines on axle. 89 older had 26 spline axles and 90+ were 28 spline.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
hectre13
Dec 11, 2023 08:14 AM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
knight72
Aug 10, 2015 09:32 PM
