How good are E-Tec Heads
Old May 18, 2005 | 12:14 AM
cutnsick's Avatar
Car: 88 GTA Pontiac right hand drive
Engine: 350 CI
Are E-Tec 170 heads worth the money over iron vortecs. The flow numbers are better but they are 500+ each as opposed to 300 for modded vortecs.
I want 350-400 fwhp with comp xr270 cam.
Old May 18, 2005 | 09:10 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
If you like less weight they are.
Old May 18, 2005 | 09:24 AM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
I think the E-tecs and like 4 other vortec heads were all tested in Chevy High Performance magizine in this July's issue. I think it was this mag, I bought it and dont remember.
Check it out!
Old May 18, 2005 | 03:28 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Check it out!
What amazed me is that they all pretty much made within 8 horsepower of each other.
Old May 18, 2005 | 05:46 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I wouldn't buy any edelbrock SBC if it was me, you can get much better.
Old May 20, 2005 | 02:44 AM
cutnsick's Avatar
Engine: 350 CI
Like what would you recomend?
Does anyone know the general outcomes from the magazine test?
Old May 20, 2005 | 10:26 AM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Check it out!
Here ya go.
http://www.chevyhiperformance.com/te...8_0507_vortec/
Old May 21, 2005 | 12:57 AM
cutnsick's Avatar
Engine: 350 CI
Thank you kindly.... Bit hard to source the mag in rural Australia.
Old May 21, 2005 | 01:26 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
True. The one thing to keep in mind though was because they were running so much compression on iron heads they used a slow timing curve in the dist to keep detonation down.
Had they taken advantage of the fact that the E-Techs are aluminum and recurved the dist, they'd have easily found more power and torque throughout the entire RPM range.
One head I was disappointed they didn't test was the Pro Toplines Vortec style heads. That would have been interesting to see.
Oh well. Perhaps I'll email them and tell them they forgot to include "Every Street-Style Vortec Head You Can Buy".
Old May 24, 2005 | 01:54 AM
cutnsick's Avatar
Engine: 350 CI
where can I find these pro toplines?
Old May 28, 2005 | 03:05 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
it appears jegs bought out topline,don't know if they will offer the 906 vortec yet.
i have a pair from just before they sold,and they are beautifully prepared!just hope they continue with the transition!
Eric B
Old May 28, 2005 | 11:08 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
It was Comp Cams that bought them out.
I have the E-Tec 200's
See sig
Old May 28, 2005 | 11:28 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Google "protopline cylinder heads"
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
